Sail number removal question.....
No real tips - they should come off pretty easy. Once you get an edge, though, go sloooowwww. It will make you pay a penalty if you get anxious and the second you try to go for speed, the number will tear and explode into tiny strips. If you are patient and go slow, it should come up in big pieces. Also go super slow at the very last bit or it leaves a tiny tip.
Once removed, if you have any adhesive left behind on the sail, use goo-gone or denatured alcohol to remove the remaining tacky spots.
I guess the cold technique may be better for Dacron numbers.
I admit I've never tried to rip them off with speed but I've removed a fair share of them. Every time I've done it, it's been room temp and I removed them slowly in order to get them to come off in one relatively large piece at a time.
For PSA Dacron insignia cloth, I'd put some Goo-Gone on them first to soften the adhesive. They should peel off pretty easily. I have a friend who swears by lighter fluid (cigarette lighter, not charcoal lighter), but I prefer the odor of citrus solvent.
Eric
we used gas as tar remover when i worked at the local car wash in the 70's. that worked great too
was probably terrible for the car's paint/finish
If you have good gloves and respirator, the chemicals that work well to dissolve the glue are xylene for the ripstop numbers, and goof-off for the vinyl glue. Maybe one or both of those works for everything. Goof-off takes of the glue from foot pads better than most other products, and xylene removes sharpie from mylar as well.
- 1,191 Online
