I20 mast re enforcement
(@azcat)
[#30601]
I want to cover a couple repair patches on my I20 mast(CF). I added a CF/epoxy patch about 2 1/2 diameter to each side of the mast at the rotator attachment. Can I use gel coat? It seems to have gel coat over a primer or transition material from the factory.
Posted : December 4, 2014 9:54 am
Jake Kohl
(@jake)
It has an Imron or some other two part paint system on it. I would use paint instead of gelcoat.
Posted : December 4, 2014 10:07 am
(@catman)
Depending on the epoxy, Gel coat (polyester) may not harden or it could react badly.
If matching the paint is an issue, use something close and find a couple stickers to cover the repaired area.
Posted : December 4, 2014 10:52 am
(@stank)
One Star Admiral Registered
I believe Southern Spars told me it was Awlgrip
Matterhorn White
Posted : December 4, 2014 1:25 pm
(@azcat)
I do have some Imron white. I guess I'll try that. Can that go directly on the repair/ current primer/ current paint?
Posted : December 4, 2014 3:12 pm
Jake Kohl
(@jake)
Yes...scuff it first with 320 grit.
Posted : December 4, 2014 4:09 pm
(@powergroove)
Matterhorn White is a shelf item at your local West marine usually, its a pretty common color and/or base
Posted : December 9, 2014 11:23 am
