Sail Tubes?
I'm into my second season looking for a sail tube and am still coming up empty. Just really looking for some 10 or 12 inch PVC to make my own. Any time I see any lying around, the contractor is not interested in selling. I've priced this stuff new, and at $10-12/foot it pretty pricy.
Don't think there are too many members from Central New York (Syracuse area), but does anybody have a line on some old PVC or an exisiting sail tube?
Danno
Danno,
Did you check on the price of thinwall PVC, which is used for underground heat ducts in commercial buildings / cement slab houses. I think you can get 14" for around $9.00 a foot. Not cheap, but the extra diameter is a bonus. Check with a local HVAC contractor that does that type of work. Maybe they will have some left over from a job??
Jack
I've found the black drainage tubing like that used on highway projects and farms is the best bet. It is rigid and sturdy, and has a smooth inner liner. I got 10 feet of 18-inch diameter tubing with a cap on one end for about $100. It can hold three or four sails, my boom with blocks and line, a tiller, and rudder connecting arm. It doesn't get much cheaper than this.
We handle the black corrugated pipe. It comes in various sizes, probably you will want the 12" double wall (smooth inside) with end plugs. They are manufactured by ADS (Advanced Drainage Systems) www dot ADS-Pipe dot com. Some local Home improvement stores will carry it. They come in 20' lengths, we sell 1/2 lengths but most do not cut them. As a ref. you can figure aro $5 per ft. plus the end plugs.
Too expensive to ship that so local will be the best bet. I've used that before and works well.
Clayton
I'm glad you mentioned the black coragated pipe. That is available and less expensive then PVC. I was concerned about whether the black pipe has any residue that will get on my sails? Any streaking problems on the sail???
If not, that's probably the way I will go.
Danno
Danno
- 3,062 Online
