Sails, Wings, and Winglets
Winglets are vertical extensions of wingtips that improve an aircraft's fuel efficiency and cruising range. Designed as small airfoils, winglets reduce the aerodynamic drag associated with vortices that develop at the wingtips as the airplane moves through the air. By reducing wingtip drag, fuel consumption goes down and range is extended.
Aircraft of all types and sizes are flying with winglets -- from single-seat hang gliders and ultralights to global jumbo jets. Some aircraft are designed and manufactured with sleek upturned winglets that blend smoothly into the outer wing sections. Add-on winglets are also custom made for many types of aircraft.
Since the 1970s, when the price of aviation fuel began spiraling upward, airlines and aircraft manufacturers have looked at many ways to improve the operating efficiency of their aircraft. Winglets have become one of the industry's most visible fuel-saving technologies and their use continues to expand.
Winglets increase an aircraft's operating efficiency by reducing what is called induced drag at the tips of the wings. An aircraft's wing is shaped to generate negative pressure on the upper surface and positive pressure on the lower surface as the aircraft moves forward. This unequal pressure creates lift across the upper surface and the aircraft is able to leave the ground and fly.
Unequal pressure, however, also causes air at each wingtip to flow outward along the lower surface, around the tip, and inboard along the upper surface producing a whirlwind of air called a wingtip vortex. The effect of these vortices is increased drag and reduced lift that results in less flight efficiency and higher fuel costs.
Winglets, which are airfoils operating just like a sailboat tacking upwind, produce a forward thrust inside the circulation field of the vortices and reduce their strength. Weaker vortices mean less drag at the wingtips and lift is restored. Improved wing efficiency translates to more payload, reduced fuel consumption, and a longer cruising range that can allow an air carrier to expand routes and destinations.
To produce as much forward thrust as possible, the winglet's airfoil is designed with the same attention as the airfoil of the wings themselves. Performance improvements generated by winglets, however, depend on factors such as the basic design of the aircraft, engine efficiency, and even the weather in which an aircraft is operating.
The shapes and sizes of winglets, and the angles at which they are mounted with respect to the main wings, differ between the many types and sizes of aircraft produced but they all represent improved efficiency. Throughout the aviation industry, winglets are responsible for increased mileage rates of as much as 7%.
Aircraft manufacturers and makers of add-on winglets have also reported improved cruising speeds, time-to-climb rates, and higher operating altitudes.
The use of winglets throughout the aviation industry in the U.S. and overseas is constantly growing. Winglets now appear on powerless hang gliders soaring above mountain ridges and from seaside cliffs. Sailplane builders around the world have included blended winglets to their designs and the sleek, graceful gliders are silently soaring farther than ever Corporate-size Learjet's were the first commercial aircraft to use winglets. Now, several decades later, winglets are incorporated into the designs of many other business jets such as Gulfstreams and the Global Express: a new aircraft built by Lear's parent company, Bombardier.
Retrofitting winglets to existing business jets is also a fast-growing market within the aviation industry itself. Many winglet marketing firms report their products help increase aircraft roll rates and lower approach and takeoff speeds.
Winglets are now quite common on large jetliners and many tower as high as six feet. The first big jetliner to carry the innovation into the air was the MD-11, originally designed and built by McDonnell-Douglas and now part of the Boeing aerospace family. Other Boeing aircraft flying with winglets are the 747-400F, the version currently being built, Boeing BBJ business jets which are custom-built 737s, and the C-17 military transport. Boeing is also offering winglet options on new advanced models of the 737 series of passenger jets.
Most prominent foreign carrier of winglets are the many models of the 300 series of jetliners designed and built by Airbus Industries. The future A380 Airbus, a huge intercontinental double-deck jetliner now under development, will also utilize winglet technology.
The first homebuilts with winglets on the general aviation market were the Vari-Eze and Long-Eze models designed by Burt Rutan, a pioneer in aircraft design innovations. Now, the majority of homebuilt aircraft coming out of shops, garages, and hangars around the world display winglets of varying shapes and sizes.
I had an e-mail discussion a while back with Dave Ellis. I had asked him his opinion about the possibility of masthead floats being designed so they actually give lift, and the possibilities of having fixed or articulating masthead winglets (which he refers to as end plates). Here is one of his responses, and I found it very interesting:
In the late 60s the A-cats and C's at Cabrillo Beach YC, Long Beach, CA, used "end plate" booms. Some used a wishbone down low with Dacron filling it in. Others used a normal, for the day, boom with Ocumme ply wings. We made sure that it was very slightly HIGHER at the clew. This was not to lift the boat, but to compress the air and make the air lift. If the Park Avenue Boom thing angled down, we felt it would blanket part of the bottom of the sail.
The old Suicide class (ask Bill Roberts) was anything-goes in monohull, but with only 125 square feet of actual sail area, including mast. It became very efficient, using an A-cat style mast and wishbone main, 1950's and 60's materials, of course. Tried was an end plate on the top of the mast. Again, it was more for reducing tip vortex than lift, although it was angled up on the front for the same reason the boom was angled down on the tack. The class ruled that they had to count the tip deflector as sail area, so it was quickly abandoned.(Most booms on dinghies are faster with the boom lower at the clew, It makes for leading edge foot, instead of trailing with its tip vortex and loss of pressure under the boom.)
On the Suicide, wind resistance on the spars and hull was a major design consideration. Many of the hulls looked like missiles or long cigars to try to cut the wind. It helped.
I'm no scientist. I do teach racing for Offshore and North U so have lots of feedback from clients. I think a wing would work IF it were not counted sail area.
In windsurfing, the sailor can re-align the sail to near-horizontal and catch air to a remarkable degree. But it also slows the board so that when it floats to the water it is barely moving ahead. If he had two sails, one to go and one to lift, hmmm. Kites are the obvious answer. I'm trying to figure out how to control it alone while sailing single-handed.
Of course, a well-designed asymmetrical chute lifts our bows. Most of the time.
I have built a Formula 14 as a test-bed. I really don't care about a Portsmouth # for it. Hydrofoils will be later. I want to try it the way it is first.
But you have made me think about a wing at the top of the mast that I can also use to keep the windsurfing sail from de-powering as fast by tiny blocks and lines leading down ala C-cat wing masts to keep the fathead leach from falling off so much. The top-mast wing would help the tip vortex thing and maybe lift the boat a bit. Kites do. Or maybe the drag would negate any advantage.
We who care not about design rules get to experiment and spend our time and money!
Dave Ellis
Not only for airplanes. Big butt Fans has added wing tip vortex's to the large overhead fans used in industry to cool factories. These fans operate at lower speeds, generate more air flow. Apparently the engineers have tested with software, wind tunnels, and independent testing.
The concept of an automatic inflation chicken float attached to a square top main and shaped as a winglet has been discussed a couple of years ago in this forum.
The idea was to improve safety and the challenge remains the same: how to maintain or improve performance through the winglet shape, given the losses due to more weight in a bad place (high).
If my memory doesn't fail, the chosen inflation system was a paintball gas cartridge and the winglet-float would be attached to the sail instead of the mast to facilitate maintenance.
Luiz
It is either that or the fact that alot of monohull class rules and handicap rules are written in a way that only used the area of the triangle between mast, deck and forestay. This same rule resulted also in designs with small mainsails and huge overlapping genua's. These setups were ONLY faster because the area of the overlap was not taken into the handicap rule while the total mainsail area was. If the rules were written to use actual area's then a larger mainsail and smaller jib would have proven to be faster.
Guys, alot of design features are the result of how the class/handicap rules were written not per se because it is aerodynamically better.
Wouter
End plate effect is accepted dogma for deck sweeping jibs.
To take it one step further. Why doesnt cruisers have deck sweeping jibs? Well, some do, but most of them retrofit roller furling, and recessing the furling drum is a major job. Newer cruisers sometimes have the furling drum recessed, but usually only in the higher price range. Another major problem with deck sweeping jibs in cruisers is lack of visibility, and building lasting opaque sails for cruisers is hard/expensive.
- 888 Online
