That being said, 9+ hours in a 17' Boston Whaler, wrangling huge marks in that kind of breeze - I'm knackered. It's time for Advil and bed.
Even on a flat lake, a 17 foot Whaler is a tough place to be all day, especially if there's more than two people on it.
Matt: What marks (of the course) are you responsible for? Are you the pin (anchored boat)?
Mike
I'm doing start pin (anchored boat), gate and finish mark. We start, blow up the finish pin (a 1.5 meter green mark), set the finish line, then tweak the gate, signal changes, then tie up to the finish mark to help record finishes. We barely have time to throw some food in out faces all day long. It's been exhausting work.
The gate marks are large:
There is a NOAA bouy on nearby Virginia Key and here were the observations recorded every 6 seconds. These are in mph. Seems pretty harry from 1-2pm and then also from 3-4:30.
Time Spd Gust
11:30 16.11 19.69
11:36 17.22 19.69
11:42 17.22 18.34
11:48 14.99 19.69
11:54 18.34 19.69
12:00 18.34 20.80
12:06 18.34 20.80
12:12 17.22 20.80
12:18 16.11 19.69
12:24 17.22 19.69
12:30 17.22 19.69
12:36 18.34 20.80
12:42 18.34 19.69
12:48 18.34 21.92
12:54 17.22 21.92
13:00 17.22 21.92
13:06 20.80 23.04
13:12 19.69 21.92
13:18 20.80 24.16
13:24 18.34 24.16
13:30 19.69 23.04
13:36 21.92 23.04
13:42 21.92 24.16
13:48 19.69 24.16
13:54 19.69 23.04
14:00 19.69 21.92
14:06 18.34 21.92
14:12 18.34 20.80
14:18 18.34 21.92
14:24 18.34 20.80
14:30 17.22 20.80
14:36 16.11 19.69
14:42 18.34 19.69
14:48 16.11 19.69
14:54 16.11 19.69
15:00 18.34 20.80
15:06 19.69 21.92
15:12 19.69 23.04
15:18 21.92 24.16
15:24 19.69 25.28
15:30 20.80 23.04
15:36 21.92 25.28
15:42 21.92 25.28
15:48 25.28 34.45
15:54 24.16 27.74
16:00 26.40 31.09
16:06 21.92 31.09
16:12 21.92 27.74
16:18 21.92 28.86
16:24 10.29 24.16
16:30 13.87 21.92
16:36 9 .17 21.92
16:42 8 .05 17.22
16:48 8 .05 14.99
16:54 8 .05 16.11
17:00 8 .05 14.99
Class has a 25 knot wind max.... So... IN THEORY.... the fleet should have been pointy end up and racing hard...
In practice... half the fleet was getting killed.... Now since this is as professional a fleet top to bottom that you will find... some might say this is a problem! Carnage well beyond bad luck and newbie racers.
Surviving the boat in 20 plus is a skill.... however... I thought the game was sailboat racing. (there are differences of opinion on this one tho)
Gee.... do you think ISAF should have allowed Nacra to fix the boat and put some t foil rudders on the thing when the boat was jumping out of the water all of the time..
An aftermarket t foil fix would have been a LOT cheaper then an 8K mast...
Perhaps they should not have allowed a half baked boat to get this far in the Olympic cycle.
It's all fun and games until somebody dies and then the coasties will get involved..
Regarding the medical staff on site,
My wife I'm sure would be willing to volunteer to be on site for the event. Plus we know the new incoming medical director of the Miami-Dade EMS and I'm sure he'd be more than willing to hear about the fact that there isn't adequate medical coverage at a world-class event like this. They mentioned that the University of Miami was supposed to be supporting the medical needs of the event but if they aren't there, thats a huge liability issue and something needs to happen.
Kate just said she can fly in if need be.
Thanks for the pic and update Matt. Are you not using a hippety-hop to retrieve the ground tackle? Those marks are big for the boat, but not huge. How deep is the water there?
Regarding safety/medical, this is an ISAF event, and Matt is a NRO with decades of cat sailing experience. By the sounds of it, they're short on assets, and Matt is living that every day. He's possibly in the best position to enact future changes. But if there's something we can do from the US Sailing Multihull Racing Committee side, let me know. Safety is one of our mandates.
Of course, isn't this the event that infamously shorted PU many years ago? Time to crack open the lessons learned reports?
Mike
Mike
When I was laying marks for JC during his practice session, the water was no more than 20feet deep. Often more shallow.
The water is only 10-15 feet deep. Pulling the anchors is not the issue (although the donated plow anchors are somewhat inappropriate). Wrangling those 2 meter diameter marks in 25 kts is a problem. They have a lot of windage - and they're heavy, with a chain bridle underneath them.
The biggest issue with the marks are the
skins
they put on them - they're very fragile and the marks cannot be towed in the water at all. The marks are yellow, but the skins are orange, so if the skins get ripped off, the marks are the wrong color.
I am in no position to affect how things are done at this event, other than to relay some of the concerns Jill has brought up to the people who might have some influence.
This is my first year here, and I'm just an Indian. I pick marks up and I put them down.
skins
Thanks Matt. Skins and chain bridles, wow. No BIMBOs were involved in the selection of those marks/tackle, evidently?
Mike
skins
Sounds like you could have used a boat-trailer.
interesting.
But were the mast breaks due to the sailing or the flip/hitting the bottom?
I am about the furthest from an engineer one can get (besides maybe an Art History major - their credo is
Fricta vis ut
or loosely translated as
Would you like Fries with that?
), but I would suspect that right about there is the second most highly loaded part of the mast?
When the diamonds are cranked along with full tension on mainsheet, that part of the mast is probably pre-bent a bit and can't flex due to the diamonds holding it in column and the mainsheet/boom tension pushing it forward?
But when you stick the mast in the mud, there's probably no way to properly determine where all the shock loading is going?
Carbon masts are speced for the N17 because they can be built to a constant standard... The tornado's had to move to a carbon stick by ISAF order because of all of the BS games that could be played with alu extrusions changing bend characteristics and still being class legal... measurable advantages to the teams with the perfect mast... but hardly one design. The class was ordered to change...
ISAF learned their lesson and required a carbon stick for the new Olympic class ...
Nacra's first stick was a total failure.... Their second stick also failed... Eventually they (ISAF and Nacra) went to an outside builder... (Hall spars I think) Why they are 8 grand is another good question.
I don't think the issue is the mast... I think the issue is the boats seaworthiness. I believe Nacra wants to fix it... but ISAF has their head up their butt and won't admit that they screwed up.
Enrique Figorora would be a good person to interview... He was an adviser to the ISAF technical committee and had a major voice in all of these decisons.
I don't think its the total issue either, but this isn't the first we've heard of mast failures with this boat.
I'm guessing the cost is relative to supply. As in I'm the only one supplying this, and I'm behind, so go f*ck yourself. It's what I would do and have done, it's smart operating.
Other than that, the C foils need to go at some point, it'll likely happen, but this is dealing with a bureaucracy, so smart things are never done quickly. How much attention would this class attract if they were flying like the NACRA carbon 20 or Phantom?
There's issues with getting them right now. Production keeps getting pushed back, which is to be expected to be honest. But they are starting to roll out.
Better platform quality wise? I don't know. My small exposure to the Phantom F18's was just looking at them at Worlds in Long Beach, seemed to be a quality product. But I think that is true of most of the boats. The Flying Phantom looks incredibly stable, and it's had buckets of money poured into it's development. I think the 17 was kind of shotgunned into position.
At this point, yeah, I'd say it'd be a better platform, but what do I know. I'm in the frozen north where my own boat doesn't get used. I'd just base that on stability. It doesn't matter how easy the boat is to sail. The level of competition creates challenges all on it's own. Squeezing that last freckle of speed out takes dedication, skill, and practice. I think the 17 would create a more level playing field if it were either straight boards, winglet rudders were added, or if it got the flying package like the Carbon 20. The A-cats weren't running C boards for very long. 5-6 years? They didn't move away from it because of the awesomeness.
So... with one race to go before the medal round on Sat... the standings are Easton, Newberry and Wilmott.
Looks like Sarah and Matt had the best regatta after the nucelar events on day one.. Easton and Wilmott finished the three races on day one wheras Newberry finished one of them. and so they eat a 50 Nobody is a clear cut front runner with the Mendlablatts in the mix as well. ...
Hopefully the new teams can continue improving at the next event in Clearwater and move up the world ranks.
Puerto Rico and Canada are leading the US tho in the unofficial handicapping for qualifying their country for the olympics.
This year's Miami world cup was not a country qualifier. Next opportunity will be the 2015 Worlds where 3 country places will be up for grabs. If a spot isn't secured there, 1 spot will be available at a Continental qualifier (likely 2016 Miami).
Countries that have qualified: FRA, ARG, AUS, ITA, NZL, SUI, GBR, DEN, AUT, NED
Hey Jeff, edit out the
in the past
part and you'd have a correct statement. How about an Olympic multi that isn't youth-sized and can handle sailing weather? Fast in 10-15kts means nothing if you can't keep your sailors (or boats) in one piece when it blows over 20.
You certainly can't blame anyone let alone Nacra or ISAF for broken masts. As Jeff said, any mast would break hitting the bottom.
Do you know how many Lasers break masts? Would you say that boat isn't sailable over 20?
How about 49ers? They break masts all the time and their masts are not cheap even despite the fact that they have multi-piece masts. The 49ers have also had multiple generations of masts and they still still break.
It's part of sailing a high performance boat.
- 1,677 Online
![[Linked Image]](http://scontent-a.xx.fbcdn.net/hphotos-xpa1/t31.0-8/q81/s960x960/10947557_1550708268518304_793257873263316136_o.jpg)
