H16 rigging question
I have a H-16 with the old style, single pulley on top of the mast.
On the main halyard (wire rope) can anyone tell me how far from the thimble (looped) end of the wire rope the
bb
should be located/swaged?
Right now it's appx 14" from the end and this seems to be the wrong distance; it doesn't lock the mainsail up far enough when it's caught underneath the...y-shaped ?halyard hook?
Thanks!
Wade H. Nelson
wadenelson@frontier.net
420 1/2 East Fifth Avenue
Durango, CO 81301-5615
970 259 1494
I waited to reply in hopes that someone knew the answer in inches. If all else fails... On a calm day with the mast down, feed the sail with attached halyard onto the mast. When it reaches its limit then back it down an inch or two and put your BB (swage?) on the halyard at the hook point. I would suggest the extra inch or two since changing conditions may make it difficult to raise the main to the extreme top position.
Good luck, I hope someone can tell you the exact measurement. My 81 hobie has the double pully system on top of the mast, so a simple measurement won't suffice.
Get it done soon. Sailing's great!
Greg H14,H16
Wade, I have mine hanging in the garage...my
BB
is 15 3/4
from the top of the shackle pin. My reefing BB is 5' from the same point. I had the same problem at first but after I started spraying the sail track, pully and
clip" with dry silicon each time I set up, it works like a charm. I also noticed that the BB had some burrs around the edges and I filed them lightly just to smooth them. I wouldn't recommend rounding the edges though and be careful not to file the cable!. Also, you might need to take the halyard well upfront of the boat to disconnect the BB when you are done. I hope this was helpful. I'm fairly new to the cats but have owned Toppers and a Laser. Fun boats but I think we all agree here that the cats are cooler!...Tom
A few questions on reefing. Does your mast have a comp-tip? Does your sail have a line of gromets five feet up from the boom? Is it easy/possible to disengage the BB and reingage the reefing BB while bobbing about in foot and a half chop in the middle of the lake? I would appreciate a description of your steps to reefing the main.
Greg H14,H16
Hi Greg, I'm at work so I can't measure my sail but the grommets are at the top of the first sail panel...(3' above the boom?) 4 grommets have lashing lines to lash around the boom and the 5th one I use to attatch the outhaul. The best place to reef is on the beech but that is not your question. I have reefed on the lake and I really had my hands full. Release the downhaul so that you are not fighting that then un-cleat the halyrard. The halyard (mine anyways) is behind the trap wires and stays, so yo need to bring it around to the front so you can get as far forward as you can in order to release the BB. Mine is very difficult to realease if I am pulling straight down on the halyard. After you release the sail to the reefing BB, lash the reefing lines to the boom, do the downhaul thing and reattach the outhaul to the reefing clew. Sounds like fun in a foot and a half of chop, hu? Take friends! As a side note when we are out with kids or non sailors that just want a ride, I will leave the sail up but reef the bottom. I keeps the boom well above everyones heads. Hope this was helpful, Tom H-16
PS My mast is the
old
style. My boat is a '72,73,74,75 etc.
<P ID=
edit
><FONT class=
small
>Edited by coolcat on 07/17/01 04:55 PM.
- 1,438 Online
