Multiple Waves on one trailer
I need to move 2 or maybe 3 Waves from Florida to South Jersey on one trailer. Do they stack easily?
With 3 would you recommend disassembling them and stacking them like cordwood (lengthwise) on a flatbed?
If I stacked them 3 high assembled would the bottom one support the weight of the two on top?
This sounds good. Since the Wave is only 7 feet wide, overlapping inverted hulls would only be 8 feet wide and I can use a standard cat trailer skeleton to build a Rick White flatbed. If I split the masts I could build a rack to hold the 6 pieces in the hole between the bottom nested boats and the whole rig would be quite short and low. The weight of 3 boats would be about 750 pounds so I'll have to think about spring capacity and use large wheels and tires. This could work.
- 3,724 Online
