Beach wheel help
Get rid of the PVC, that was for the old style you don't need it anymore. You should have 20 delrin rollers inside each hub. All you need is a the flat stainless or nylon washer (mine has both) that sits right against the rim on each side to hold the rollers in place. Give the rollers a spraying with sailkote before you seal em up. If you are converting from old style to new you may need to drill a new hole on one side for the cotter pin to go through as the old holes were wider apart.
sailkote is not recommended for bearings.. it will cause sand to stick to em' and leave flat spots
fresh water rinse is suggested
FWIW
Didn't know that I kind of treat it like WD40 for the boat. A little here and there helps everything. 😀 But mostly I apply it to the edge of bolt rope that hits the track most every season.
Edited by Quarath on Jul 19, 2012 - 01:39 PM.
- 5,823 Online
