Hobie 14 Stern Deck...
Hobie 14 Stern Deck Lip Damage
[#3111]
This Hobie 14 I'm fixing up has the broken deck lip at the stern where the rudder pin hold is supposed to be. I've seen this type damage on a lot of Hobie 14 & 16's. Since the area is solid fiberglass I'm thinking I can just dremel away any loose parts and fill with marine tex to smooth it out. Doesn't seem worth getting into actual fiberglass work.
On the starboard side it looks like someone used a hacksaw to remove loose glass and cut in too far.
Any suggestions for a quick stable fix?
http://www.thebeachcats.com/pictures/?g2_itemId=88367
Posted : July 17, 2012 11:41 am
Let's see...you're 6'7"ish & you are "fixing up" an H14.
It begs the question, do you have a kid you haven't told us about, a new,(small) GF?
It is hard to tell how deep the damage goes on that right hull, but really glass is so easy to work with, I would grind it away, on a bevel, with the angle grinder, use any 6 mil sheet of scrap plastic sheet as a form & lay up 4 layers of woven roving at a time. It would only take an hour or so, then, using the gudgeon as a guide drill upwards through your work.
It will be as strong, or better than new.
If you want it to look really good, finish 1/16" below fair, then use a gelcoat kit.
Posted : July 17, 2012 1:48 pm
(@rattlenhum)
You're right, Damon.,,,,the hole is just a place for the pin to go through...no other purpose. Just smooth it up and seal it good so no water can get in the laminate. I have rebuilt one with just thickened epoxy, but it was only cosmetic.
Posted : July 18, 2012 6:46 am
Very funny, watch for this one in the classifieds soon. Decided to see if I could join the ranks of the money makers here at TheBeachcats and sell some stuff myself. 😎
Although I do plan to put it in the water for a test sail and pictures, we will find out how a H14 sails with 238 lbs onboard.
rattlenhum wrote: You're right, Damon.,,,,the hole is just a place for the pin to go through...no other purpose. Just smooth it up and seal it good so no water can get in the laminate. I have rebuilt one with just thickened epoxy, but it was only cosmetic.
Thanks Jerome, that's what I thought. I'll leave it to the next owner if they want to pretty it up.
Posted : July 18, 2012 8:19 am
(@drummer63)
DamonLinkous wrote: [quote=Edchris177]
LOL _ I said the same thing last weekend. I weigh about that and have put together an old 14 for my 12 year old son. Decided to "Float Test" it and ended up sailing for hours cos it was so much fun...one sail, easy rigging and supported my fat a@@ no worries. May be taking it out for a spin tonight 🙂
Edited by Drummer63 on Jul 19, 2012 - 09:01 AM.
Posted : July 19, 2012 3:00 am
(@rattlenhum)
DamonLinkous wrote: Although I do plan to put it in the water for a test sail and pictures, we will find out how a H14 sails with 238 lbs onboard.
Since you have like an eleven foot wingspan, I'll loan you mine, then you can lash the two together and ride 'em like one of those gals on a pair of dolphins at Sea World! Now I'd pay good money to see that!
One word of advice....don't sit anywhere near any of the corners. That thing will roll over in any direction, and they turtle easy, too!
Posted : July 20, 2012 5:52 am
(@klozhald)
Damon, get some Sorlarez Extreme, pick a sunny day and you can have that filled in with a minimum of effort, and it will be strong. http://www.solarez.com/productsnew/e_extreme.html
Posted : July 20, 2012 8:17 am
