Hull deck plates
Here's a great article in Hobie Hotlines that details a process using a silicone mold to retexture a repaired deck. Check it out!
Molding link
Application link
removal of the entire deck lid for a single point of access might be discouraged. you are looking at scraping apart the joint of the lid from the hulls (with a screw driver or chisel) and HOPING not to do damage that will need repair.
It is do-able but i would think a simple 4" or 5 (or 6) port would be much less drama, work etc. Not to mention it will then offer you storage.
I had 2 ports that i used to access my front hulls to add a simple eyestrap (with backing plate) for my front tramp tiedown.
This is the inside of a Mystere 6.0. (deck lid) and chain plate. i wouldn't want to remove that.
edited by: andrewscott, Aug 31, 2009 - 11:24 AM
- 2,653 Online
