Prindle 16 help
DO you have any loose blocks that came with it at all the you could take a picture of and we could see what you do and don't have? or is there no blocks at all.
You should have something like this for the Main goes between the end of the boom and the traveller car on the rear beam. http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Product_Code=28-61&Category_Code=C-M&Store_Code=MS
And a couple of thease for the the Jib http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Product_Code=28-0188&Category_Code=C-J&Store_Code=MS
as well as something like this for the jib clew http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Product_Code=28-0371&Category_Code=C-J&Store_Code=MS however it does not have to be this you can make something from a couple individual blocks. In fact the manual for the boat says to just tie them to the clew with a short bit of line. but is is a more modern version I guess.
As I have a P18 I don't want to tell you about the halyards as I might get it wrong I'll let someone else
Also those were just easy images to get Don't feel like you have to buy these new. Give Prindle Pete a call at 909-800-5237 or email him at pbegle@charter.net and see what he has.
Here is a diagram of the jib rigging:
And one of the trap rigging:
Best I can do on short notice with a slow day at work.
edited by: Quarath, Aug 28, 2009 - 10:27 AM
Brandon, One of first things you'll need to know for sails is what jib you'll need. If you have turnbuckle at end of forestay and rope halyard with hook, you'll need ZIPPER luff jib. If no turnbuckle and chain plate at bridle, you'll need wire luff jib (like H-16). Pete 909-800-5237
- 3,472 Online
