Identify Paint
Technical Help
2
Posts
2
Users
0
Reactions
2,058
Views
I recently got a pair of banged up hulls. Looking over them, its fairly apparent that they had a coat of paint or gelcoat rolled on at some point in the past. Is there any way to tell what it is? I know some paint is fairly toxic when sanding, but I need to do some repairs on them and that will require me to remove some of this outer coat.
Posted : February 24, 2010 8:05 am
hard to cost effectively identify paints but a charcoal filter respirator (3m 40$) and some rubber gloves and a tyvec suit(8$) will protect plenty. if your feelin frisky you could strip the paint first but be warned, it can be severe pain in arse sometimes. if i were doing a "restoration" then i would strip it first, make repairs/fairing then paint. if not then patch and go!
Posted : February 24, 2010 2:37 pm
Forum Information
- 4,856 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
