NACRA 5.5SL and 5.8 Mast Length
Technical Help
5
Posts
3
Users
0
Reactions
4,128
Views
Found this for Nacra
Nacra 5.5sl
Length: 18' (5.49m)
Width: 8'6" (2.59m)
Drafts:
Boards Up: 5" (12.7cm)
Boards Down: 34" (86.4 cm)
Sail Area: 241 sq. ft. (22.39m2)
Weight: 375 lbs. (170.1kg)
Mast Length: 29'7" (9.02m)
Nacra 5.8na
Length: 19' (5.79m)
Width: 8' (2.44m)
Drafts:
Boards Down: 38" (96.5cm)
Sail Area: (251 sq. ft. (22.39m2)
Weight: 410 lbs. (181kg)
Mast Length: 30'7" (9.32m)
Posted : August 30, 2018 7:59 am
Forum Information
- 346 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
