Catyak rigging
Technical Help
2
Posts
2
Users
0
Reactions
1,649
Views
The Sunfish uses a gooseneck (sort of)
http://www.sunfishsailboats.com:80/Sunfish_Gooseneck_Assembly_p/90638.htm ="> https://www.sunfishsailboats.com/mobile/product.aspx?ProductCode=90638&404;http://www.sunfishsailboats.com:80/Sunfish_Gooseneck_Assembly_p/90638.htm=
I guess you should pull it down with a downhaul line.
Or just tie the boom to the mast with a couple clove hitches, we did so several decades ago. The mast came with no shrouds, a good line is enough. Forestay is not needed
Posted : August 27, 2018 11:11 am
Forum Information
- 2,162 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
