Nacra playcat aka Escape 2008 yellow loosey goosey mast
Hi
First post here, kinda know what I'm doing. I wanted to check with some of you how you woul connect shroud line without adjuster? Would you use just a small shackles?
Reason I'm asking is I currently have adjusters on both sides and lines are hooked up to the lowest hole...
I'm thinking just to hook up directly. Mast play in waves is scary, and i just want it tighter
Let me know what your thoughts are...thanks
Posted : September 19, 2016 4:51 pm
Forum Information
- 2,284 Online
Our newest member: Ejustes
Forum Icons:
Forum contains unread posts
Topic Icons:
Not Replied
Replied
Active
Hot
Sticky
Unapproved
Solved
Private
Closed
