prindle 16 jib rigging
I'm still confused on the jib...I'm a monohull sailor just got a prindle 16..so question the jib zips around the forstay..I'm told it also zips around the jib halyard ..if that is the case how do you haul up the jib??I'm used to hooking to the head and pullin the halyard and tying off at the mast??so if the jib halyard is zipped in how do you haul it up and do your secure the end to a cleat...just in case you have to drop the jib..still not clear on this..glennbob
the halyard is on a turning block on top.
you feed the halyard through the zipper and as you pull down on the halyard... the head goes up.
you progressively zip... as it goes up. when you have it all the way up, and you have the desired jib luff tension, you secure it with a rolling hitch (or knot of choice)
andrewscott wrote: the halyard is on a turning block on top.
so the halyard both ends are zipped in the jib?
pbgaja wrote: thanks so the halyard I tie off at the bridle?so there is no way to quickly lower it from the tramp..??
Correct. Don't worry, it's not really an issue.
pbgaja wrote: so the halyard both ends are zipped in the jib?
Yes, the forestay and halyard both end up inside the sail to present a nice clean leading edge to the wind.
my friend steve has the forestay tied to the ring (blue line) and is tieing off his jib halyard
Here is my jib furler, you can see the white line securing the forestay and my blue jib halyard (PS i use the same blue line to first secure my jib tack, then i use it as my jib halyard/downhaul)
What no one is telling you is that usually the jib halyard is in 2 pieces connected with a sister clip. Once you get the jib up this clip should be located at the bottom of your jib pocket. You can then disconnect the extra section of halyard and stow it either in a tramp pocket or in your trailer gearbox.
I only recently got all this figures out myself and I still won't have mine setup right till I set the boat up for this season.
I know this is not what you were asking below but just in case you need it.
and
The halyard attaches to an S hook which in turn is slipped through a loop at the jib head.
Draw the halyard down inside the zipper area, zipper area encloses both the forestay
and the halyard. The S hook will slide up to and then engage, as you pull the
jib down, a floppy ring just below the halyard turning ring that is
at the mating point between the upper forestay and the lower forestay.
Pull up to the limit, draw down slowly to engage S hook, draw down sharply to
prevent hook engagement. sister clips should be placed on the halyard so that
it is near the bottom of the jibs zipper pocket with the jib fully raised.
Jib tack line should go from the grommet, through the forestay / bridle
wire clip then up to and secured at the clam cleat attached to the jib itself.
On the P16 & P18 the jib luff tension is set and not adjustable on the fly.
MX rigged boats are a different animal altogether.
Hope this helps.
edited by: ButchG, Mar 09, 2010 - 07:45 AM
glad i read this post...when i got my boat, the jib halyard was run through cleat on mast. used it all season last year like that until the upper forestay pig tail snapped. thinking about it, that way "tweeks" the short cable by pulling it torwards the mast, through the jib keeps the pressure straight on like its designed...so i'll be doing it right this year...de-masting at warp speed was a little too exciting!!
Quarath wrote: What no one is telling you is that usually the jib halyard is in 2 pieces connected with a sister clip. Once you get the jib up this clip should be located at the bottom of your jib pocket. You can then disconnect the extra section of halyard and stow it either in a tramp pocket or in your trailer gearbox.
and
thanks on this it does help..it makes more sense to me now...you haul the jib pull it back down to engage the s ring...that way it takes the load off the forstay which isn't very big and the jib pulls on the mast and the jib halyard assits the forstay on the load...with a clip you can just as you said remove the excess halyard and store it...my next question is about a 1/4 of the way up on the mast is a bracket fastened to the mast any clue on its use..right now just the jib halyard is attached to it..but I suspect it may have another use as it is really rivited to the mast ..possibly a way to attach something to help single hander raise the mast??
P-16 mast and jib could be a little different than what I am used to on my p18 so I am not sure what that cleat is for. The P16 I think has a pulley on both the front and back at the top of the mast and the p18 only on the back for the mainsail. Could be the p16 jib does go through the one on the front and cleat to that or it is used for something else entirely I am not sure.
- 5,995 Online
