Prindle 18 rigging
I just got a new (1981) P-18 and have been working on fixing it up. I cleaned up the hulls and found no soft spots. I rewired the trailer and greased the hubs. Now the boat... as this is my first sail boat (other than a Snark) I have no idea how to rig it. I have the owners manual but it does not show line routing directions, knots, etc... Any good books or information out there? I have a new trampoline and new line kit from Salty's to install. I have the tramp figured, but not the lines. Thanks!
Edited by twilliams.907 on Jan 26, 2011 - 05:42 PM.
couple of great albums others have compiled here with some info
http://www.thebeachcats.com/pictures/?g2_itemId=76587&g2_GALLERYSID=ba80b04746627e3e798ff0a3307362be
http://www.thebeachcats.com/pictures/?g2_itemId=62059
Look at the pictures in the manual very closely and you should be able to gt some idea of how it is supposed to be rigged.
Good Luck!
I am originally from Davis. Check out Hobie Fleet 2. I know they sail primarily Hobie's but a good family oriented group that is fun to sail with. They do a lot of sailing/camping weekends, even social events in the winter. Their members are all over the foothills and Sacramento area. Probably the highest concentration of H18's you will find anywhere.
My brother is in the fleet.
Rider_55 I looked at the Jib rigging for the P18. I have a SC15 that rigs the jib sheet block sort of the same. A 1/4 inch line tied back to a padeye. I was wondering how the shock cord to the center of the tramp changes the performence ?? I was trying to work out a bauber hauler system for my SC15.
Looks like the shock cord keeps the blocks from banging on the hulls and bouncing around when sailing. If it is loose enough it shouldn't impact the block or line orientation when the jib is under power. Just keeping the upwind block from flopping around. I had looked to do something similar on a SC20 once.
- 3,175 Online
