Referbing Hobie 18 ...
Referbing Hobie 18 Thread
16 Users
29.2 K Views
http://skipmeisch.com/slo…grades/tips-GinPole.html lso
if there is a will, there is a way
not sure how your gonna prevent side to side sway with his setup
the E-Z mast system i had back in the day used the front trap wires as guy lines
Posted : March 19, 2015 4:40 am
(@dogboy)
A couple suggestions on mast raising....
Having a helper with you, at least for the first few times, is invaluable. Even if the weight of the mast isn't an issue, having someone there to free a fouled wire or connect the forestay is a huge help. The 18 mast is pretty heavy, so lifting with two people makes things a lot easier, especially if there's a cross breeze.
That being said, if you're strong enough, raising the mast solo is certainly doable. Some things that will make it easier- Take the boat off the trailer and put it on the ground before raising the mast. If this is an option, it makes things a lot easier. The boat is more stable when on the ground. You can also start hoisting the mast from behind the boat and walk forward up onto the tramp, raising the mast as you go.
Another thing you can do that helps with solo mast raising is to bring a 6 foot ladder with you. Put the ladder about 10 feet behind the boat. Pin the mast base to the mast step and then lift the mast up on to the ladder. This will prop the mast up at a higher angle so it is easier to start your lift - you won't have to bend over as far to pick up the mast. Then make sure all of the shrouds and trap wires are routed inside the rudders and clear of any snags before you lift.
Posted : March 19, 2015 10:23 am
(@goodsailing)
I built Skips gin pole. 8' long with teepee end comprised with channel that will fit mast to a T, no pun intended. $12 total cost including metal. I had to add some pieces of 2x4 to the 2x4 to stiffen it as, single 2x4 seemed to springy. Yes, having help at first is good idea, but I don't have help. Crew is in Aruba at the moment and wouldn't help anyway as they flew the coup;;; KIDS--spring break ta da. . Thanks for the EZ diagram. I had already determined to sling the hulls on both sides but couldn't figure out the blocks to ensure tension is equal on both sides of the gin pole to keep it from swaying, plus to keep the gin pole vertical until I can tension the raising line. Yes, fix gin pole, jump down to reel in raising line etc.
I want to get the mast up to fix the lines for the traps. Can't adjust unless it's up. I'll let you know how it goes, the gin pole that is... it's wood and I'm now thinking steel tubing would be more compact. I could have welded it in less time than what it took fooling with wood. And it looks like it needs paint.
Posted : March 19, 2015 11:37 am
(@goodsailing)
Well it's snowing so ... I'm going to fix the trap lines once the snow melts provided my gin pole works. 😆 They sell rope grabs for $25 @x4=$100 for adjustable on the fly trap line. I'm thinking Blakes Hitch. Basically a prusick knot. With two lines, one is attached to the eye and used to tie a blakes hitch to the second line that is attached to the dog bone. You basically lean back and the line connected to the eye with the Blakes Hitch grabs the rope connected to the line that has the dog bone arresting your traveling backward. To adjust, you simple put your left hand on the knot and move it, while holding the other line. No hardware needed. Anyone use this knot? Remember, before all the technology, only ropes were used. Hardware replaced knots.
Posted : March 20, 2015 5:26 am
(@goodsailing)
Fail: The wooden gin pole didn't seem substantial enough. I'm not sure the amount of force that is created but it was enough that caused the gin pole to bend away from the centerline of mast. Once the mast was under tow it began to swing. I felt like a crane operator wondering if 1. the gin pole would break, 2 the mast would cant and break off from the mast step. I disassembled the contraption and got out ladder. I heaved the mast up on a ladder placed near the transom. I got up on the boat and attempted to lift the mast. It was harder to lift the mast from this elevated position than having the mast lay flat. This means, that not even using a ladder, when you hoist the mast up to that point, is where it becomes harder. I got out the aluminum motorcycle ramp and placed that on the rear xbar and attempted to walk the mast up the ramp... but nearly half way up I felt the ramp was too unstable, let alone the mast was unwieldy, the thought of coming down the ramp, de-masting would have been impossible.
The idea to to deal with this boat by myself on the ground is becoming ever more sketchy. If I can't get the mast up, I'm pretty much dead in the water so to speak. Let alone, de-masting. Then there is the physical aspects that once the mast is wrestled up, you're too exhausted to sail the boat! If in fact I really Umph it up, risking injury.
Any ideas?
Get help?
Join club where help might be available?
Scrap the project?
Sell the Hobie?
Concentrate on finishing the Proa that will have an easier mast set up.
Buy a Hobie Kayak with a sail--- (I know now why that's a trend.)
Also, if two people raise the mast, where do they stand and what do they do as I really don't see where a second person can help. I already had the mast up as high as a person could hold with the ladder and still couldn't get the mast up past my shoulder while standing on the tramp. Could the foam in the mast be holding water? I drained water out but perhaps the foam is water logged making the mast heavier than what I've seen in the two part video Rigging Hobiecat 18 on Youtube?
Thanks for any help... as I'm somewhat defeated at the moment. 🙁
Posted : March 22, 2015 12:45 am
(@goodsailing)
Not defeated yet:
I looked at this video
I noticed the receiver in the mast for the gin pole. I've decided to use my boom as the gin pole. So I've made a female receiver for my boom goose neck. If it slips I'll tack weld it, but I looks pretty sturdy. I'll complete the rigging like this video using the tramp lines and extending two lines down from the end of the boom (gin pole) etc. I'll let you know how it works. Oh, I'll use the wooded gin pole as a crutch for the back of the boat to lift the mast up to get it started.
http://www.thebeachcats.com/pictures?g2_itemId=113139
Posted : March 22, 2015 7:43 am
(@timinaustin)
You should be able to life the mast by yourself. Easy way is to put cat on beach wheels so that it's nose down. Place a ladder (at least 6') behind the boat and lay mast on it. Crouch at rear crossbar and put mast on your shoulder. Stand up with mast on your should, turn and face front of boat. Walk forward on the tramp, using your arms to "walk" the mast into the upright position. Once it's all the way forward, the raised rear of the cat will help hold the mast up. At this point I was have two trap wires run forward and tied together with a rope. Run the rope through a block somewhere on your trailer, and back through a jib cleat. Cleat the rope off to hold the mast while you pin the forestay.
I can heave up the 30' stick on my Nacra, so you should be able to get yours up too. Other option is to rig up a winch on your trailer. You can pick one up for
Posted : March 22, 2015 4:36 pm
my 6.0 (31') mast was solo stepped using a homemade wooden ginpole (6"x2") for a year before i purchased it
it's all about technique
Posted : March 23, 2015 12:53 am
(@goodsailing)
I get putting the cat on the ground but I've not built beech wheels yet. So when the nose is down and you step up on the back of the boat holding the mast, won't the back of the boat go down. Unless of course the wheels are all the way in the back? I'm going to try my boom as gin pole today and will let you know what happens.
Also, are you putting a milk crate on the ground to jump up with the mast, 22" or more the height of beach wheels to get on the tramp while walking up the mast?
Edited by goodsailing on Mar 23, 2015 - 07:30 AM.
Posted : March 23, 2015 1:13 am
you put the wheels almost all the way back to prevent ANY chance of you teeter tottering with a 28' stick in your hands/shoulders
this can also be done with a trailer. put the bows down and rest the sterns on the trailer wheels (Trailer must be attached to car or other static object)
you should be standing on your tramp
if your not using the yoke of a trailer you need to use the ladder to get the angle of the mast working in your favor
crude photoshop work here....
Edited by MN3 on Mar 23, 2015 - 08:33 AM.
Posted : March 23, 2015 2:31 am
(@goodsailing)
I installed my goose neck to the mast and rigged everything. The mast rested on a big cooler. Boom was on the tramp. I put the rope that went through the block on the trailer on the tramp. While on the tramp, I hosted the gin pole, (boom) that had all lines connected. I had the side guides connected to the bungie on both sides. I got up on the tramp and hoisted the boom up and put it in the hole of the part I described above. While trying to juggle holding the boom there I tensioned the guide lines so both were equal. The boom was vertical and aligned with the hull. The tramp lines were attached at a point where the side lines were attached. I started to tension the blocks and as soon as everything was tight, my hand still on the boom (gin pole) I gave a little tug. I felt the power of the block start to take purchase. I eased back further.... and as I was looking at the boom position I hadn't noticed the mast lifted off the cooler but began to rotate to starboard. Then the boom tilted. Here I was on the tramp trying to hole the pole verticle and the mast was swinging to the side. The mast hinge broke on one arm and the mast further rotated. It was now laying on the rudder. I lifted the gin pole up and lowered it. Got the mast back on the tramp then the other hinge arm broke. Fortunately I had placed a huge garbage can under the mast. So now the mast was resting on the garbage yet laying unfixed on the front xbeam. I disconnected all the lines and put the boat away.
There is absolutely no way one can lift this mast up without some type of rear rigging to keep the mast swinging. Attaching the tramp lines added no value. The boom, blocks and my little goosneck appeared to work. No gin pole needed to be build. Lifting off the cooler works.
Now, after I get the hinge replacement at $50 🙁 I'll attempt this again. I'll tie the mast between the hull at the transom to keep the mast from swinging laterally while I get the boom in position and get tension on it to keep it in place. I believe you'll need 2 lines. To hoist, the main line that does the lifting, and another line that will keep the mast aligned at the back of the boat. While pulling the block line to hoist, you'd have to let out the line in the back as the mast goes up etc.
Then there is the consideration of the mast crutch taking all the stress. I've seen pictures where base of crutch gave way.... perhaps bottom block needs attached to main bottom beam of trailer, not boom crutch above the crank.
Needless to say this is going to take a lot of rope. I had 90' for the main hoist line. Perhaps I could handle the mast with one hand at the rear, keeping it steady, while using the teeth/ hand method to yank the hoist line. This way would eliminate effort, just touching the mast to keep it straight. Much of this is technique... I guess.
This is turning into a time consuming and now costly experiment.
Thanks for all your help. I'm investigating beach wheels so that I can possible work at this while boat is on the ground as suggest above, but carrying a ladder too?
Posted : March 23, 2015 5:56 am
(@nacra55)
Foam in the mast? And water? Probably mud too. The mast needs to be clean, dry and water tight. If you do get the mast stepped and get on the water, when you flip, if the mast weighs as much as you say, you will never right the boat especially solo. THIS IS DANGEROUS. Fix your mast before you go any further.
Posted : March 23, 2015 6:12 am
Andres Chianale
(@Andinista)
About the angle of the boat: It's quite a lot harder to lift the mast if the bows are point up as in the second picture rather than down. This is because you would be holding the mast from a lower point, closer to the base. As you are so close to the lower end of the mast, the difference in lever arm is very significant, more than you would probably think. I learned the hard way lowering the mast on an inclined spot.
Edited by Andinista on Mar 23, 2015 - 01:21 PM.
Posted : March 23, 2015 6:52 am
it is possible
i did it all the time with the ez step
the mast did swing until it was dialed in for me (you use the trap lines, not a tramp line)
and a friend took out his front window before he had his dialed in
Posted : March 23, 2015 7:22 am
Andres Chianale
(@Andinista)
About getting help to raise or lower the mast, I think that the best option is to have someone pulling a trap wire from the front. Two from each side is a bad idea, one is good help, the same that helps you grab the mast and get started, goes forward and help you raise it. I think it's described this way in the old nacra or prindle manual.
Another advantage of raising or lowering the mast with the boat on a significant angle (bows down) is that it can be held up just by gravity while you get donw and pin the forestay
Edited by Andinista on Mar 23, 2015 - 01:28 PM.
Posted : March 23, 2015 7:26 am
(@goodsailing)
Not available: Incline the boat forward, and additional help. Yes Trapeze lines. They produced no value in keeping the end, top of mast from swinging. At least that is my experience. Here's my next option: run a static line between two rear hulls with a block dead center. Attached by butterfly knot etc. Attach a retrievable line to the mast somehow as you need to get it off there to raise the sail, plus you need to get it back on there, when the mast is up to lower the mast, through the block on the line then forward through the main sheet cleat: Main fact is: there needs to be enough tension on the mast and the pole to keep everything lined up and stable prior to raising. Mast can't rotate and neither can gin pole. The whole rig must just stand there, without movement, prior to lift. Mast needs elevated prior to lift, otherwise downward pressure of front line will push gin pole to the side. That's what happened, then without the mast tethered at the rear it swung.
If you had two people holding the trapeze lines perpendicular to the mast on each side might, and I say might, keep the mast from swinging pending if two people could keep constant equal pressure, otherwise if one pulled more than the other, mast would swing. Being away from the end of the mast, one might not see lateral movement etc. The mast hinge broke at less than half distance from hull to center hull cleat so it must stay absolutely straight. I supposed you must have worked for the circus putting up tents and trapeze wires to know all about what the heck is going on here.
Not including wind forces.
Thanks for you help and your following along. We'll get there.. believe me. Work stopped until mast hinge shows up.
Posted : March 23, 2015 9:26 am
(@goodsailing)
And he must have broke the hinge because it can't go that far. Lucky I didn't break the ears off the bottom plug. As you'll remember: I couldn't get the plug out! I wonder if the hinge metal is softer than plug. That hinge was bubble gum metal, that flaky silvery stuff.
Edited by goodsailing on Mar 23, 2015 - 03:47 PM.
Posted : March 23, 2015 9:46 am
His was a supercat 17
my mast would swing the more i raised it.
i would lower it and adjust the guy lines (whatever side it swung to was too tight
0nly took me about 4 hours to dial it in in the fl sun
but once it was set up it was fine
PS if you can get a helper.. i think the easiest is to have him/her get on the tramp with you (boat can be on ground or trailer) and both of you pick up the mast and walk it fowrard
when it is up, one of you go forward and pin (or secure) the forstay
on our beach when we get a helper, we tie a bowline around the forestay and give them a long line to help PULL when we lift the mast out of the trailer craddle (sterns towards trunk on trailer)
Posted : March 23, 2015 12:10 pm
Goodsailing,
I feel for you I really do. Trying to get this figured out completely alone by random people's written suggestions and some videos is tough.
And just to let you know, in the 20+ years I've sailed Hobie 18's I've broken quite a few mast hinge castings. The local Hobie dealer jokes they have a standing order for them just for me.
I really wish you had someone who could walk you through this in person, with an experienced hand around you'd have it figured out in no time, rather than trying to invent a method for something that's been done untold numbers of times before.
I'll share my first time mast raising story, the say misery loves company.
I'd never owned a catamaran before I bought that first Hobie 18. I bought it well-used but good sailing shape from the local dealer. The dealer gives me a copy of the Hobie 18 Assembly Manual (or I think sold it to me) and away I go to the lake on a Wednesday.
There is no one else around and I've never even seen a Hobie 18 fully rigged.
Five hours later I've got things put together (I think) and ready to raise the mast.
Did I mention there was no one else around?
I went through this whole mental process of how it would go and ended up "inventing" this method to raise the mast alone. (it didn't actually occur to me that I should have help, since the dealer assured me I could single hand the boat)
1. Drove the boat over to the steep launch ramp and pointed the boat down the ramp.
2. Used a PFD to cushion rear beam and connected mast hinge to mast base, that leaves 20 feet of the mast unsupported behind the boat, quite a bit of pressure on the hinge pin, but doable if you are gentle.
3. Tied an extra line onto the end of the forestay, and ran it forward around something on my vehicles trailer hitch and back onto the tramp where I could get to it.
3. Stood on the tramp beside the mast, next to the rear beam.
4. Dead lifted the mast up to shoulder height (about six feet) and then walked forward pushing the mast the rest of the way doing my best imitation of the Iwo Jima Memorial. Here is where the severe bow-down angle of the boat really paid off because once I got the mast past 45 degrees it got easier instead of harder to raise. And once it was up it was actually leaning naturally forward against the shrouds.
5. With mast up I simply reached down and reeled in the line that was attached to the fore-stay and tied it off loosely to the mast. So now the boat had a temporary fore-stay and I could climb down.
6. Now comes the hard part... I completely underestimated how difficult it is for one person to connect the forestay adjuster to the roller furler. With the furler already attached to the bows you have to use one hand to raise the furler to height, one hand to bring the forestay adjuster down to it, and the other hand to insert the clevis pin.
7. Drop the clevis pin and then the ring ding, spend quite a bit of time looking for it since it rolled down the hill and blends in with the rough asphalt launch ramp.
8. Finally give up and wave down a ranger cruising through the area and get him to provide the extra hands needed. It was getting dark so I think he just wanted me out of the area.
That's all there is to it!
Posted : March 23, 2015 12:43 pm
(@goodsailing)
Helpers not available.
Incline not available.
Objective: raise mast by oneself, with common materials. The less common materials the better: ladder, y support etc. Cooler works, diy gooseneck for boom pin works.
The existing boom and blocks work. The sheet is too short so you need longer line. Lucky as former climber I have rope.
An arborist, who deals with falling limbs above would know how to construct this...,
The oscillation of the mast top will be most dramatic the lower it is, when shrouds have less effect. It is this point that the mast needs controlled. If you run with the sheet, hauling the gin pole down, the oscillation diminishes as the mast is raised. I'm almost thinking straddling mast , or tying it off, while you fix the pole, then handle the mast to keep it straight, and you pull the sheet/teeth-it , while holding the mast I would be most effective. I can lift the mast. I can't lift he mast to my shoulder while standing on the tramp. The diamond wires are in the way etc. Bounciness of the tramp cause ill footing. So if I can provide mechanical leverage to get the mast up high enough to shoulder it, then I'm home free, I just push it up. I probably won't need the leverage once I get it on my shoulder. I suppose I'm looking at 30 degrees travel that I need help, hence the gin pole.
I think the video up there of the Hobie 21 show he ran with the sheet... the faster it raises the faster the oscillation diminishes. Hinge would probable never break when mast is up 45 degrees. Only break below that. The mast becomes more stable the higher it gets. At low point is most problematic. You've see cranes, little happens up high, its when weights are swinging wildly down low the problems occur. No doubt proper lines, and technique, are sought.
The mast is stable on your shoulder. Getting to that point is the problem.
Yea, getting it dialed in... 😆
Edited by goodsailing on Mar 23, 2015 - 07:10 PM.
Posted : March 23, 2015 1:07 pm
Funny, just stumbled across this Hobie 18 mast raising video, not sure if it's been posted in this thread yet or now. It's pretty much how I describe above.
My story about raising a mast solo for the first time (and nearly the last) above happened in 1991, (before Youtube and even before the Web) this video is from 2010. Some things get invented over and over. He does it in a flat parking lot, it helps to start with a really loose rig, put the shroud in the very top hole of their adjusters to give yourself as much break as possible.
Thing is, in his video there are lots of people walking around in the background, I'd just grab a few strangers to help. 😉
Posted : March 23, 2015 1:30 pm
(@goodsailing)
I can tell you I'm really appreciative of all the tips.
I've watched the video you posted a lot. It's the heave part and getting around the diamond wire to put the mast on the shoulder is the crux. Yes an incline would help, after through the crux, but it's the crux that is the stumbling point. The life jacket was worthless for me. You will note in the video the mast is still on the rudder bar anyway. I tied a cooler there as it will move out of position if not tied to the tramp. I've also left the roller furling unit attached to the chain plate so that it is already held up to hook the two side wires once I got the mast up should that occur. Everything but the crux, can be accomplished pretty easy. Finding a dropped pin, not so easy. Then there are safety issues. Would you get under a suspended beam just above the crux held there by a gin pole arrangement. To push the mast up the rest of the way. I don't think so. Consequently, once the gin pole technique is started, you have to take it all the way.
So the matter for me is, if the gin pole doesn't work, then I absolute need a helping hand to get it up.
IF that is the case, where's the video showing 2 or 3 people getting this mast up. I have no clue how to instruct a helper. Where do they stand, what do they do. Where do I stand, what do I do. It's still impossible to pull wires through the crux IMHO. For instance, no two people could hold the mast at the crux by holding wires.... unless of course if the two people where 40 ft in the air on ladders above the mast. I'm not driving a fire truck to the water. So even needing help, I have to know how to direct someone to give the help I need... getting past the crux. Hell my neighbor could help, but I don't know how he could help, quite frankly. Where is he supposed to stand, and what should he do. When he's doing what he's suppose to do, what do I do. Perhaps he could jump up there and muscle it up through the crux. If so, my job would be to WATCH him, and tie it off and pin the forestay while he holds the mast. If these questions can't be answered, then, I'm back to the gin pole. I wouldn't ask my neighbor because he might hurt himself etc... not being an experienced Hobie 18 mast raiser. I'm all for asking for help, but other than, hey jump up there, and muscle up the mast for me, I don't have a clue in asking for help. For the cost of the hinge I could have hired the guys standing around the home depot looking for work. But again: other than, muscle it up for me, what should they be told.
Glad to know breaking mast hinges is a common problem. Hence emphasis on keeping the mast straight as it is lifted by gin pole or brute strength.
I do realize putting the boat on the ground would change handling the mast. I suspect the crux would be less, as you'd already be under the mast at the crux point.
Edited by goodsailing on Mar 24, 2015 - 03:42 AM.
Posted : March 23, 2015 9:27 pm
as i mentioned above:
PS if you can get a helper.. i think the easiest is to have him/her get on the tramp with you (boat can be on ground or trailer) and both of you pick up the (pinned) mast and walk it forward
when it is up, one of you go forward and pin (or secure) the forstay (the other stay and hold it upright)
Posted : March 24, 2015 1:10 am
Andres Chianale
(@Andinista)
I usually do everything myself too, sometimes I get some help just to hold the mast up once raised, and eventually to get some initial angle at the beginning. The day when I really got away from the being in the edge of misery was when I got beachwheels. That's the single device that will help you the most. Sliding the boat out of the water, if at all possible, is a huge pain that you will avoid. Getting some independence from your trailer can be a major help too. It even enables you to get the boat off the trailer to the ground and back again, all by yourself. Not something you really need but in a few situations you might find yourself wanting to have the boat on the ground rather than on the trailer. For instance, you can use the trailer mast cradle instead of a ladder to get some initial angle. I often get the boat off the trailer to the ground instead of the water, just to avoid submerging the trailer lights. I'm probably a bit obsessed about that, don't take it as an advice.., just consider that it's not a crazy idea.
In my experience (with a different boat by the way), raising the mast from the tramp is the simplest way once you get used to it. The critical part is getting the diamond wires out of the way and having the mast on your shoulders. From there, extending your hands is the next hard part but after that you are almost there, the weight comes down very fast as the mast approaches the vertical. If you watch a few videos you will notice that some people give the mast some speed in the first pull and use the momentum to save the intermediate position (mast on shoulders) and go quickly up. If you could get a lot of initial angle to save the first part it would really make things easier. With the boat on the ground you are in better shape, so it's probably a better option to get started. Maybe you can also figure out a raising system with your winch trailer but without a gin pole, which is actually useful only on the initial part with the low angles.
On the last video, where the mast is secured up with a line that goes through the trailer winch, I have a couple comments, if you think of that option:
- The guy leaves the line on the tramp and then gets it with one hand and with the other he holds the mast. That's a very dangerous position, you better avoid it, get the line closer to your hands, a quick knot on the diamond wires or duct tape it to the mast.
- If you think of using the mainhseet or jib sheet to get some purchase on this line, or just to be able to lock it easily, be very careful that it can be uncleated, the angle to uncleat may be wrong and if you get stuck in the middle of the process (i.e. side stay caught on the transoms, very typical), you will be in deep sheets.. you can't raise nor lower the mast and cannot even get out of there...
Posted : March 24, 2015 1:15 am
(@dogboy)
goodsailing wrote: Helpers not available.
Raising the mast solo is doable but difficult. Raising the mast solo without ever having raised the mast before successfully is nearly impossible as you are finding out. There are techniques that make raising the mast easier but these come with experience. You live near Baltimore, right? Why not just bring your boat to the Hobie regatta this May at Gunpowder Park? It should not to be too long of a trip for you and there will be people there who can not only help you raise your mast but also show you how to fully rig your boat properly. You will learn more about your boat in one or two days than you possibly can learn after weeks of posting on the forums.
Just something to consider.
Posted : March 24, 2015 3:19 am
Dogboy wrote: You will learn more about your boat in one or two days than you possibly can learn after weeks of posting on the forums.
And the choir said, AMEN!
Posted : March 24, 2015 3:28 am
(@goodsailing)
Dogboy: If your going to help me, where are you standing and what are you doing? And what would I be doing as you are doing your thing. Watching you?
I expect to attend some sailing groups near me, but this problem shouldn't be too hard to figure out. The question is: should I continue with the gin pole idea or concentrate on lifting technique.
Andinista identified the crux as I have. Dead lifting the mast up to where you can get underneath it to lift it. Think Olympic weight lifting. The problem is small platform where your stance is compromised, including having to change hands on the bar. You will note in the video the person actually lets go of the mast, holds the mast in one hand, to change hand positions around the wire. Its already been mentioned that momentum is used just as in weight lifting to get the weight up to the point where you can change positions. This is a matter of technique. Where you put your feet, hands, and what body movements are needed to get the mast on your shoulder. I've mentioned too, because I've been up there, as the mast is raised it become more difficult off the deck a ft and becomes harder, due to the fulcrum how the mast is attached adding to the problem of shifting hands, feet, body etc. The center of gravity shifts as you lift.
Now if this is the ONLY way you guys raise masts, then it's pretty simply. Jerk the mast up with both hands, at apex, let go with one hand, get it around the wire, stoop, get under, get hand back on mast and it's on your shoulder.
1. If I can't muscle it up, then
2. Gin pole
3. If not gin pole
4. then someone else must stand up there.
What technique is used lowering the mast. I can just see myself after a rough day of sailing holding a lowering mast with one hand, trying to get my other hand around the wire and off my shoulder.
I ordered the hinge. Nothing much more to talk about until the hinge gets here.
Edited by goodsailing on Mar 24, 2015 - 01:58 PM.
Posted : March 24, 2015 7:55 am
Andres Chianale
(@Andinista)
Never tried it, just thinking out loud:
Have your boat on the ground instead of trailer. If yor cooler is strong enough, put it behind the rear beam and use it as a step. Start lifting the mast from the ground to avoid changing position
Posted : March 24, 2015 1:30 pm
Andres Chianale
(@Andinista)
One stupid question, just in case. When you were trying with the ginpole, the trap wires wiere attached to the front beam and no further aft, right? I remember trying this long ago without the swinging you describe. I didnt use a pole, just the trailer winch, but started from an angle, i don't remember sll the details but i do remember using the trap wires without any issues.
Posted : March 24, 2015 1:36 pm
(@dogboy)
Any of the above. There will be people there setting up their boats. You can watch how they raise their masts and observe the process. If you want assistance getting your mast up there will be people around to help. Often when there is a group of hobie sailors rigging their boats and one person is ready to hoist their mast, all they have to do is ask one person for help and three people will come over. One person grabs the back of the mast, one person raises the mast, one person pins the forestay, and others are around to clear fouled wires, help lift, or do whatever is needed. It just makes the operation run very smoothly. There are more than a few experienced "old guys" in the group that have done this for a lot of years.
Posted : March 24, 2015 5:39 pm
Page 4 / 9
