stealth marine F16 needs a new daggerboard!
6 Users
(@sindrulf)
[#29106]
Suddenly today the leeward daggerboard broke in half while we were out in the waves. I am trying to contact John Pierce. Is he still active with his boats?
Posted : May 28, 2012 12:32 pm
(@jalani)
The Stealth F16 uses a standard 49er daggerboard. Any 49er supplier could sell you one.
John is still around and making to order. He can be contacted via email at stealthmarine(at)tiscali.co.uk
Posted : May 28, 2012 1:09 pm
(@sindrulf)
Wow! Nice to know. Thanks!
Posted : May 28, 2012 2:16 pm
(@sindrulf)
Oh my god they were expensive!
Ovington Boats have them at 577GBP. Do you know of any other shops in europe?
Posted : May 28, 2012 2:28 pm
(@Anonymous 13024)
Build one <img src="<>/wink.gif" alt="wink" title="wink" height="15" width="15" />
Or repair the broken one, if you still have both parts..
Posted : May 28, 2012 2:52 pm
pgp
 pgp
(@pgp48)
Speaking of building. Is vacuum bagging small parts (dagger board size) worth the effort? I'm doing something similar and it seems good vacuum pumps are expensive.
Posted : May 28, 2012 3:34 pm
(@jalani)
Try Simon Hiscocks at Schock Sailing:
Schock
Posted : May 28, 2012 3:57 pm
(@Anonymous 13024)
If you are getting into building, get a vacum pump. If you have a compressor you could consider a cheap venturi vacum pump. Alternatively pick up a used refrigderator compressor from a recycling center.
Posted : May 29, 2012 1:40 am
(@waynemarlow)
I think the later Stealths has a specific board and not the 49ER which the early boats had. Length was the same but very different in chord width.
I have a spare wider 49er style board which is sitting in the back of the garage which I could sell for not a lot of money, where are you based ?
Posted : May 29, 2012 4:23 am
 Cab
(@cab)
Pete,
I have had great luck with one of these. No oil. Does not get hot even when running for 12 hours straight. Around $250 seems to be the going price on ebay for a used one.
http://www.ebay.com/itm/Welch-2585B... ps&hash=item43af0f721e#ht_522wt_1398
Posted : May 29, 2012 7:18 am
pgp
 pgp
(@pgp48)
I'll give it a look thanks! What was the application?
Posted : May 29, 2012 8:09 am
