7:1 to 8:1 conversion
I agree with Andinista and have recently added another block to my 8:1(even after reading this thread).
Sure i can now probably apply more force, but i don't want to. my goal was to need less strength to sheet to the same amount (i have shoulder issues).
Also i have a hard time believing the sheeting forces are the same on an f18 and n20... but i am not an engineer
Upgraded
an 8:1 system to a 9:1, but the existing block hardware was not beefy enough to handle the loads, found out the hard way 3 days into Tybee.
This statement suggests that an increase in purchase means necessarily an increase in max load applied. Is that really true? Don't we want to actually lower the pull to acheive similar results? Therefore more pulleys should mean lower load and not higher, except at the connections in both ends, where the total load is applied.
That's assuming that the goal is to distribute the load rather than apply more total tension. Maybe I'm wrong there.. Still, we are talking about a 10 to 15% increase in purchase, which comes with a decrease in overall efficiency because of the higher friction, therefore, the total tension is increeased in less than that. Would that be enough of an increment to break the blocks? If not rearranging blocks too differently (like the single block suggested in the first post) I think it shoudn't
http:/
I ran mine like the other example, though I came up with it through trial and error.
I could not make fine adjustments with 7:1, to sheet hard I'd actually lift my butt off the hull, that resulted in steering all over the place.
What do you think?
Whoa! cats cradle! The top block needs to be at 90 degrees to the triple
Upgraded
Nacra 20 has a softer, bendier, mast so you have to be careful not to oversheet more so than the F18...but, we sheet them similarly.
Upgraded
If you added a point of purchase you decreased the load on the hardware (blocks)itself. I think you were just using some old busted-butt, brokedown, shite. i've used an 8:1 modded to 9:1 since it was allowed by class rules ,at least 4 Tybees worth.
? I thought it was easier to oversheet Rob's wildcat than Forrest's N20 - both in 18+ conditions... maybe I was just seeing things? Or are you referring to the N20 with aluminum mast? I never considered that carbon mast particularly
bendy
+1 on that Karl!
I don't recall anyone ever breaking a mast from oversheeting a main (on any boat except maybe an H16 before they started raking the masts back). Even with the 10:1 setups?
Only N20 masts I've heard that broke were stuffing into a wave with spinnaker up (Mike H), letting the mainsheet go with the spin up, and getting tossed around at Jensen Beach during the T500. Maybe there are more out there?
Can you oversheet the N20 to the point of breaking the mast? Using the OEM 8:1.
Forrest
I doubt it. In big air upuwind and sheeted properly, the I20 mast looks like a wind surfer rig to me. After sailing F18 for a while and coming back to the 20, I had to get used to seeing that much bend in the rig. I'm not sure you could do any damage even with 10:1 though.
- 5,051 Online
