main sheet washing overboard
Isn't that the crew's job? ...... Come to think of it, isn't *everything* the crew's job?
You're right, Tracie
That's why in the past year I decided just to give the whole responsibility for the mainsheet to the crew, trimming and all. Let's see, crew now takes care of jib, main, downhaul, rotation, barberhaulers, boards . . . .
I have had trouble with waves washing the main sheet over the back whilst going downwind with kite, traveller center and main cleated. This can cause a very worrying situation when it tangles around rudders or tiller extension. Aslo has un cleated the main risking the mast.
I now lay my leg over it whilst sitting on the back beam or hold the traveler when trapping.
Oneday we'll all revolt. Then you'll be sorry.
Muhh-ha hahahaha
Tracie
For the benefit of novice sailors and for crews who do not know why the skipper is always yelling to get the mainsheet back on deck, would somebody like to explain WHY it is so important that the sheet not go out the back of the boat? (Besides the possibility of it getting wrapped around the rudder.)
A trick that works for me (fyi... I also have the hook velcro at the back of the tramp)
I have a mountaineering grade caribiner that I run the main sheet through. The carabiner is then attached to a high quality snap shackle that is attached to my harness. The mainsheet follows me hands free in hectic or crash conditions and also acts as a safety line if I were to get washed overboard...the mainsheet sheets in as I get towed/trolled
and the boat capsizes instead of sailing away...if in trouble or hooked up just pull the lanyard on the snap shackle and the caribiner and main are free to go.
That's a little something that I have added as a safety and control feature for distance racing.
Fast and safe sailing,
Jim Stone
It can get caught on something in the water.
It slows the boat down.
It puts the sheet out of reach of the skipper in the case he needs to blow it.
I could name others. Did I pass?
Rick has always held his own mainsheet, but my job as crew was to make sure the sheet stayed on deck. He explained to me that the reason he gets so frantic when the sheet washes out the back is that the pressure can be so great (water pulling the sheet) that he would not be able to release the mainsheet and let it out, if necessary.
- 5,754 Online
