Should the Code 0 gennaker be used at the Olympics
And why not, this sail was devellopped by 3 highly professional teams over a period of years in a class with highly skilled and dependable sailors using the conventional setup and thus acting as the benchmark. How much better can a real life test be ?
I find it pretty instructive that 2 out of 3 teams who were party in developping this sail choose not to use it. Apparent they knew indeed what its limitation are and decided against it as soon as the predictions didn't show a series of days with the assumed narrow band of conditions.
I compare it to the test with the hydrofoils in the C-class; sure some say that that too was only one event with only 4 boat participating. However, for something to be a
new wapon
it needs to show significantly improved results at one point. Both hydrofoils and this code-0 aren't doing that in their first real tests. As a result the questions presents itself whether this pathway is sufficienty promising to continue. Again the current results are far more supportive of a negative answer then any positive one.
Of course this all withing the limits set by the Tornado class rules and upwind-downwind bouy races. The code-0 has proven itself within the other classes like the ORMA-60's and indeed the Extreme-40's. However mostly for other reasons then all out performance.
Wouter
Wouter,
An reason why this regatta might not be a good place to make decisions on the code 0 after the americans poor regatta is, maybe, they just had a bad regatta.
Tom Slingsby current Laser world champion also had a poor regatta result finishing in 22. Can't blame that on a poorly perfoming Chupacabra.
Skill, mental conditioning and equipment. Charlie and John have proven that they are good under pressure (Athens). They have good understanding of the geography/meteorology. That leaves the equipment.
To see what they say about it themself: http:/
Sailing is a weather dependant sport and everyone knows you can not depend on the weather.
ALWAYS choose your equipment for the versatility and abity to perform in the widest possible range of conditions.
If you are playing the numbers game and can change equipment like a recreational windsurfer changes sail size as the wind varies through the day, OK. If you are planning for a week or longer event well off into the future, selecting equipment for a narrow performance band will be a big mistake more times than not.
There were only 2 of the 3 teams at the Olympics. So only 1 of the 3 teams choose not to use the sail.
I have used similar sails and I suspect the problem has to do with the difference between testing and racing. I found a hooter to be a big advantage when sailing against only a few boat, in clean steady air. I found it sucked when faced with the chaos of many boats going in different directions and shifty varying winds
Yes, but Bundock and Ashby had a code-0 project of their own that was pretty well developped. They too decided against it and that makes 3 teams in total even when the PUR guys fell away as you say.
Wouter
From Team USA Blog:
Today with a strong current running up the course, we had very quick upwind legs and long downwind legs. The wind out of the west was very shifty and puffy, blowing between eight and 15 knots. Conditions were difficult with lots of position flip-flops in the fleet. We sailed really, really well today, the best we have in this regatta, but our sail choice worked against us. We were always making gains on the short upwind legs and even sometimes on the long hauls downwind. But the fact was that the small spinnaker killed us downwind.
Today we learned over and over and over again, a lesson that we’ve already learned a million times - no two regattas are ever the same and it’s never like you think it’s going to be.
So, having a strong current shortened the time spent going to weather, increased it goign downhill...further minimizing the benefit on the CO.
Seems the winds were above what had been seen in the 3 year lead up. I'm not convinced the C0 is a failure based on this regatta.
one could also have said :
... further aggrevating the drawbacks of the CO.
Kind of halve full halve empty type of things.
Wouter
![[Linked Image]](http://sailjuice.squarespace.com/storage/IMG_0904.jpg)
Images from Andy's SailJuice blog. The sail has a specific application. If the Tornado series had started a week earlier, the outcome would have been different, and the conclusions just as invalid.
Both the Tornado and Star classes had significant equipment differences that, while within the rules, make some people uncomfortable. We'll see if ISAF or the IOC decide there are lessons to be taken away. If the event had been as light as the vast majority of us expected, the US teams in the Star and Tornado might have done much better, which would very likely have led to some serious discussion about
one-design-ness.
Now I wonder if those conversations will take place. <img src=
So, the tornado, hobie wave, and taipan have all had luck with the chupacabra\code zero\hooter\upwind gennaker. What other classes have been able to pull it off?
I frequent inland lakes that often have light and shifty air. 4-8 knot winds are not uncommon. Could I pull it off on a hobie 16?
More importantly, could it be pulled off on a Mystere 4.3??? And would it be class legal on the 4.3????? Yeah, I'm thinking about buying one.
It does not look like the T has pulled it off at all.
Could be a bit quicker upwind in the 3 to 7 knot range but all else, forget about it.
Don't forget this sail was developed with 3 to 7 knots in mind against a strong current against you upwind. Without the current on the nose upwind, you are giving away a large advantage to the standard boat around the bouys.
one-design-ness.
One-design may be good for the Olympics, but is incredibly boring. Intelligence and improvement require more space. The most politically correct one-design would be the Optimist. The youngest athletes in the games would deserve a lot of media attention.
The Chupacabra reminds me of Eric Tabarly. His open minded developments made him the greatest rule optimizer/bender. The Fastnet winning schooner with an enormous genoa between the masts forced a rule update. The depleted uranium keel forced another one, and the water ballasted solo transpac another. His hydrofoil tri motivated the categorization (does this word exist?) of the transatlantic record to separate monohulls from multihulls. The sea lawyers really had to run to keep up with his pace.
None remembers the sea lawyers who fixed the rules after his inovations (and achievements) - but all sailors remember the great man.
The Chupacabra is an innovation that Tabarly could have created. He would have loved it. The initiative is admirable of those who developed the sail, as is the courage of those who dared use it. Wining or not.
Cheers,
one-design-ness.
Cheers,
Well Said Luiz!
<img src=
- 2,240 Online
![[Linked Image]](http://towardintelligence.files.wordpress.com/2007/09/geez-magazine-find-the-eyes-to-see.jpg)
![[Linked Image]](http://catsanddinghies.nl/img/news/large/_DSC0261med.jpg)
