Jib Halyard
2 Users
(@Anonymous 32191)
[#12053]
Having problems with my jib halyard on my hobie 16.It seems fine untill I hook up the jib and raise it then it has a twist at the top.When I rigged the mast I put the shrouds and forstay shackle on the middle hole of the mast tang and put the trap lines on the lower hole.Can this cause a problem?Also my main halyard the wire part has developed some kinks that has made it difficult to keep it against the mast when raised.Any suggestions would be appreciated
Posted : June 8, 2003 8:27 pm
mmiller
(@mmiller)
The standard tang has three holes. The main shackle that carries the shrouds and forestay use the lower hole on the tang. These hang from a 5/16" shackle. The 1/4" shackle for the trapeze wires hangs from the top hole. The "hoop" or bell of the shackle passes through the larger/center hole.
Be sure that the jib halyard wire is routed cleanly. Shouldn't be another cause there.
After hoisting the main, I hook the halyard at the top... then bring the halyard out, aft and around the starboard shroud. I then loop the line under the downhaul cleat and only then do I tie it off on the starboard mast cleat. Pull enough tension to keep the kinks out. That will keep it well clear of the jib while tacking.
Posted : June 9, 2003 11:08 pm
(@Anonymous 32191)
Thanks for the reply.Only thing I,m not sure about is the shackle you say to put through the middle hole.Is there not only two shackles?
Posted : June 10, 2003 6:32 am
mmiller
(@mmiller)
There are just two shackles.
One 5/16" Bell for the forestay and shrouds. Hangs from the lower hole.
One 1/4" Bell for the trapeze wires. The shackle pin passes through the upper hole and the body (bell or hoop) of the shackle passes through the large / Center hole. Hang one set on each side of the tang.
Posted : June 18, 2003 8:17 pm
(@Anonymous 32191)
great thanks again.The set up also solved my jib halyard problem
Posted : June 19, 2003 12:04 pm
