Naming your cat
they are a whole lot better than the sails on my 420
Here we go...put up a picture of you sailing and you better get ready to get...well...reviewed. <img src=
Jib's too tight and it's clearly stalling the mainsail. This usually happens before the leading edge of the main caves in but you're clearly in full on choke the main mode there. <img src=
ooohhh,,,
penny drops, thought dennis was ragging on the age/condition of the sails not their trim
yes, now i see that jib is hauled in way to tight and directing air INTO the main and not around it
in fact it looks like the only thing stopping the luff of the main from full collapse is the battens
must keep and eye on that
thanks for the call
Erice, my message was quite ambiguous. Probably because I wasn't 100% sure what was wrong there myself.
Jake seems to have had little doubt though!
Sorry for the Hyjack everyone!
(personally I don't think renaming is bad at all, if Poseidon disagrees I'll take him on any day!)
What happens if you take two boats and make them into one? Do you end up with a boat that has two names?
What happens if you replace the hulls on your boat?
What if you keep your hulls and replace everything else?
bad luck to rename a boat? - YES, bad mojo
two boats and make them into one? - Add a hyphen
replace the hulls on your boat? - check to see if your life insurance is in order
hulls and replace everything else - drink 2 bottles of rum, spin around 24 times counterclockwise and sacrifice a chicken.. you should be fine
- 3,144 Online
![[Linked Image]](http://i222.photobucket.com/albums/dd275/spridle22/IMG_0365.jpg)
